Not feeling any colder... A/c Compressor?
Old Jul 1, 2011 | 09:31 PM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
So it's only been 3 weeks since I recharged (after finding out from the mechanic that it's been retrofitted...) R134 into the system
Assuming he's done all the dye checks and leak sealing
Now my a/c isn't working. I feel no temp difference from Vent and Max cooling.
And I notice that the engine rev bobs up and down and correlate that with the compressor coming on and then off as in the video
http://www.youtube.com/watch?v=tNhaR6tLxP0
Is this acting normally? or did my mechanic miss a leak causing the AC to not cool anything.
Old Jul 2, 2011 | 12:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Not feeling any colder... A/c Compressor?
if the compressor is contantly cycling its an indicator of low freon. it could have a slow leak and leaked out what you put in.
take it to a shop that was an AC machine and have them pull a vaccum on it. if it hold a contant vaccum for say an hour, then chances are its not leaking and it just wasnt filled enough.
Old Jul 2, 2011 | 01:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
After you recharged it, was it blowing cold then? And have you run it since then ?
Old Jul 2, 2011 | 07:27 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
That's cycling too quick. You have a leak somewhere.
Old Jul 3, 2011 | 09:44 PM
Krishan's Avatar
Engine: 5.0 305 TPI
Yeah, it did blow cold air, everything worked.
I told the mechanic to let me know if there was a leak, no reply, just got the car back and assumed it was a simple recharge.
Three weeks later I'm getting air no colder than on the VENT setting.
Definitely a leak then- Idk where though.
Old Jul 4, 2011 | 11:15 AM
Car: 1989 GTA
The shop "should" have put in some sort of dye to detect a leaky area. Even if they didn't, they usually have a leak detector probe. Sort of like a small metal detector, only it fits in your hand. They wave the wand over the system and where there is a leak, it will beep.
It could be something as simple as a leaky schrader valve. In that case, the car will hold a vacuum (since the valves are open with the hoses connected to the A/C service ports.) But once the hoses are removed, the schrader valves are supposed to stay closed, but may leak.
Galaxie500XL
Feb 1, 2020 04:53 AM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
Ironhead38
Sep 7, 2015 02:26 PM
