a/c comp problem
Old Jul 2, 2011 | 09:07 PM
big.jack's Avatar
a/c comp problem
89 FB w/ 305 tbi all stock.
just bought a new a/c comp. and i went to change it when i noticed there were 2 plugs on the back of my old compressor and only 1 on the back of the new one. one is a flat 2 blade plug right behind the clutch and the other is a round 2 prong on the back of the unit (this is missing in the new one) what are the 2 plugs and can i just jump it? the new comp. has an empty spot for it with a snap ring and the old comp. plug is held in by a snap ring. do i just swap it?
any help is thanked
Old Jul 3, 2011 | 01:59 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: a/c comp. problem
That is the High Pressure switch. You need the 2 wire plug. any auto parts store will have or get one. Just take the single wire and attach it to one wire and ground the other. I just had to do this on mine, I switched to R4 compressor. The R4 units have 2 or 4 wires HP switch. My new compressor had no switch. My old one single wire. I don't know if the HP switch interchange. Remove snap ring pull the old one out and see if it works.
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
mz92274
Aug 25, 2015 08:47 AM
