how do i replace t-stat housing???
Old Jul 4, 2011 | 08:22 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i bought a new t-stat and gasket but i dont know how to change it... how do i get the new unit inside the rad cap??? heres a pic...
Old Jul 4, 2011 | 08:26 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Re: how do i replace t-stat housing???
pic
Attached Thumbnails how do i replace t-stat housing???-dsc01293z.jpg   how do i replace t-stat housing???-dsc01294z.jpg
Old Jul 4, 2011 | 09:00 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
pic
Old Jul 4, 2011 | 09:07 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
thermostat is not under radiator cap . follow upper radiator hose to engine . the metal part the hose connects to is the thermostat housing . remove the 2 bolts and remove it . there is the thermostat . good luck .
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It doesn't go under the radiator cap. It goes under the water outlet on top of the intake. 2 bolts (can be 1 bolt & 1 stud with a nut on it) hold that down, but on TPI the throttle body make is a little harder to reach than on a carb'd or TBI car.
If the bolt and/or the stud break off? You are in a world of hurt trying to get the broken part out. Trust me on that.....
Old Jul 4, 2011 | 09:13 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Thermostat is in the intake not the radiator. Follow the upper hose coming out of the radiator to the intake. You should see 2 bolts on the metal housing bolted to the intake. You loosen those bolts and the housing will pop loose. The gasket goes between the intake and that housing. The thermostat sits under that housing on a recessed lip. You'll lose some coolant. You can either drain some out of the radiator on the lower corner using the valve or you can use a towel to soak it up. Make sure you replace the coolant with pre-mixed or 50/50 water to pure antifreeze.
Old Jul 4, 2011 | 11:22 PM
NxtLevl's Avatar
Car: 1992 Z/28
Engine: 5.7 TPI
On a TPI car, it's alot easier to remove the TB to give you plenty of room to get to the housing....It's only a few extra minutes to remove the TB, and saves you alot of headaches...........
Old Jul 5, 2011 | 05:50 AM
Engine: 383 SBC
I've done it without removing the throttle body. IMO it's just one more thing to worry about. Especially since this is a 700r4 car.
Old Jul 5, 2011 | 11:53 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Also I didnt see a thermostat gasket in your pic, make sure you have a replacement before you begin.
Old Jul 5, 2011 | 11:54 AM
Engine: 383 SBC
It's in his 3rd post. :-)
Old Jul 6, 2011 | 08:59 PM
89RsPower!'s Avatar
ah ha, must have scrolled down too fast
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
