metal heater hose line leaking
Old Jul 6, 2011 | 07:01 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
the metal line that my heater hose connects too is leaking around the clip that holds it to the body. iv always noticed it leaked but ever since my cars been down it must be leaking horribly because i lost my entire coolent bottle full of coolent and over half my radiator
Old Jul 7, 2011 | 09:54 AM
Engine: L31 350
Re: metal heater hose line leaking
help, maybe its my diverter line, how do i plug it? i really need to get this fixed. what are the worries about plugging that line?
Old Jul 7, 2011 | 10:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just replace it.
Old Jul 7, 2011 | 04:07 PM
Engine: L31 350
how? where can i get a new one
Old Jul 7, 2011 | 06:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Replace it with a regular heater hose, no need for the metal line.
Old Jul 7, 2011 | 10:46 PM
Engine: L31 350
but its metal all the way back? can i get a heater hose that long? i have a rubber heater hose but near the body it goes onto a metal line that goes back to the firewall, its below the diverter line. how do i plug the diverter line so i know its the metal line its self.
Old Jul 7, 2011 | 11:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Even if you found one, you will never get that line off. I just removed an engine from an 88 GTA today, and that line won't come out until the engine is out.
Just run generic rubber heater hose and leave that pipe where it is.
Old Jul 7, 2011 | 11:11 PM
Engine: L31 350
thats the weird this is that it didnt start leaking till AFTER i swapped engines -.-, i dont know what you guys mean by running a new heater hose line. explain please because i already have the rubber hose on there.
Old Jul 7, 2011 | 11:24 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It was probably rusted already, then when it was disrupted during the engine change, it popped.
Of couse even steel lines need to have rubber on the ends for the connections. We are talking about removing the rubber end connetions you have now, and buy heater hose by the foot and run it the full length of were your old rubber-steel-rubber lines were.
Old Jul 7, 2011 | 11:33 PM
Engine: L31 350
ohhhhh. ok now i understand, thank you!!
Old Jul 8, 2011 | 06:02 PM
torque_is_good's Avatar
it's the 3/4 inch hose and you'll also need a 3/4 inch tee.
adv auto doesn't carry the tees but autozone does
Old Jul 12, 2011 | 10:22 PM
Engine: L31 350
got the line installed today and no leaks but im having an issue, its not getting a good flow where it goes throw the alternator bracket, its trying to fold over so im not going to get the best heat like i did, any way to fix this?
Old Jul 13, 2011 | 01:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why is it going through the alternator bracket?
Old Jul 13, 2011 | 08:27 AM
Engine: L31 350
thats how my factory one was ran, it came off of the metal line, up under the alternator, threw the bottom of the alternator bracket to the heater line on the waterpump.
Old Jul 13, 2011 | 09:04 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Get a piece of 3/4 copper tubing that is bent to fit the area and it will not kink. You can go to a Air Conditioning shop or a place that sells copper fittings and take a piece of your hose and get the length, size and shape piece that fits.
Old Jul 13, 2011 | 09:40 AM
Engine: L31 350
thank you, i didnt think of that either
Old Jul 15, 2011 | 06:45 PM
good grief
run the hose under the A/C lines and it lines right up with the radiator
it really isn't complicated. If it's kinking, you cut the hose too long
Old Jul 15, 2011 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Or too short.
Old Jul 15, 2011 | 10:11 PM
Engine: L31 350
good grief
the heater hose doesnt go to my radiator, its on my waterpump....
Old Jul 16, 2011 | 08:42 PM
ahh, 2.8
Old Jul 16, 2011 | 09:02 PM
Engine: L31 350
yes, it has to run through the alternator bracket to even get to the nossle and its trying to close on the bend to get to the neck its self. i need to go get the copper tubbing
1992 Trans Am
May 10, 2023 07:19 PM
mike_c
Aug 27, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
