Air conditioning hose swap question
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I am doing a motor swap soon, and am keeping AC. Currently my stock AC hoses have a leak and my ac only lasts about a month if that. They are the kind that run over the radiator shroud, here is a pic:
I want to get new AC hoses, but I dont like how intrusive these are, the way they wrap around the engine bay and look like crap. I would like to use this style hose:
http://cgi.ebay.com/ebaymotors/Ready...Q5fAccessories
(Bummed this picture from Bota 65, hope thats okay.
I figure that they have the same fittings, and ends and what not to make them work, they're just in a less intrusive shape.
Simple question, but I cant seem to find an answer..
Thanks!
)I figure that they have the same fittings, and ends and what not to make them work, they're just in a less intrusive shape.
Thanks!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Air conditioning hose swap question
Just a thought ... The A/C hoses you have linked are for a 2.8 litre 6 cylinder - your sig states a 305 V8 motor - not sure if they are the same (length or whatever) or not - may need to verify as a larger motor might need more A/C line length.
Yeah I am not sure about that exact link, I was trying to show the shape of them, and how they run lower than the ones that I have. I can't seem to find new ones specifically for my motor. I am swapping a 355 in, but keeping the same accessories, so no changes there.
Up..
Anyone done this swap?
Bump..
Anyone know where to buy these new?
Found these on the napa site:
https://www.napaonline.com/Catalog/C...+50012+2012008
But no price and it doesn't say if they're even available. I thought it would be easier to find these. lol
I am pretty sure that the fittings on the lines would be the same, so I am willing to take a chance on that part.
I just need to know where to buy new AC lines? Anyone?
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
If you are anywhere in the Broward County area of Fl my buddy Jon of Jons Auto Air makes A/C hoses. I have an 86 IROC that he just made all the hoses for and had my compressor rebuilt.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It looks like your existing hoses might be able to be tucked under the upper rad support. No?
My current hoses leak and are garbage as far as I am concerned, and I fear that if they are bent down in front of the radiator, that it would accelerate the rate of wear and they would just develop a leak faster than if they were left alone.
Car: 1986 IROC-Z
I will ask him tomorrow as the price I paid was for compressor and hoses, but I dont think it was very much.
Car: 1986 IROC-Z
I talked to him and he said between 80 to 100 for both hoses. He would need the Manifold and connectors attached to the original hoses.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You can always swap to the serp setup which puts the compressor on the pass side and not worry about ac hoses running all over the engine bay...just gotta do a little rewiring for the alt and get a reverse flow pump.
1992 Trans Am
May 10, 2023 07:19 PM
