AC Vent won't switch
Old Aug 5, 2011 | 05:10 PM
iceman383ja's Avatar
Car: 91 Z28, 2014 ZL1
Engine: 383, LSA
Transmission: WC T-5, T6060
Axle/Gears: 3.73 in both
I'm trying to figure out what controls the movement of air from the defrost part of the dash the vents...any help would be great. I have already started checking all of the connections behind the control unit and everything still looks to be good shape.
Old Aug 5, 2011 | 05:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: AC Vent won't switch
When there's a vac leak, the default setting is defrost.
JamesC
Old Aug 5, 2011 | 06:43 PM
Engine: 383, LSA
Thanks bro, I started testing all of the vac's behind the control unit and manually turned on different portions. Not sure what is bad at the moment....thinking it may be the control unit. I think the leak maybe from the vac line in the engine bay to the control unit now....It won't hold any pressure
Old Aug 5, 2011 | 06:52 PM
JamesC's Avatar
You might stick your ear to the HAVC and listen. If you hear a leak, your problem probably6 lies with the following part: Valve Vac Sel GM part # 16032395.
JamesC
Todd84Z
Sep 4, 2015 08:02 AM
Jk_Under
Sep 2, 2015 10:59 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
ZsTransAm
Aug 11, 2015 07:30 PM
mustangman65_79
Aug 11, 2015 03:17 PM
