question about the daul fan set up
Old Aug 8, 2011 | 12:50 AM
zst90's Avatar
Car: 1987 firebird ta, 1985 chevy 4x4
Engine: 305 tpi, 383 for 4x4
Transmission: 700r4 in ta, TH-350 in 4x4
Axle/Gears: posi on ta
hi was wondering how exactly the dual fan set up works. on my 87 trans am the left fan will run and the car will stay at 180 when on the highway but if im in town or sitting the temp will just go higher almost getting to the red part. and the right side fan will not move at all. is there anyway i can get these fans to work like they are supposed to so i can drive without worrying about the temp going up to far.
Old Aug 8, 2011 | 10:30 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: question about the daul fan set up
Here's an article from the technical articles section that explains the set up. Lots of good stuff to go over in that section. Your fan switch is probably defective. Do a search on the cooling board for much more info
https://www.thirdgen.org/electric_co..._spec_mod_dual
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
gta power
Aug 13, 2015 06:15 AM
Leggman1
Aug 6, 2015 04:15 AM
