3rd gen ls1 overheating
Old Aug 15, 2011 | 10:33 PM
ls1spyder's Avatar
Car: 1992 CAMARO RS
Engine: LS-1
Transmission: 4L65
Axle/Gears: 9". 410's
Well heres the deal. Everything on my cooling system seems to be working. Fans r running. Not loosing any water. I have an aftermarket temp gauge from autometer. If im on idle or running down the freeway my gauge just keeps gettn hotter and hotter. It will literally go up to 240. But when i shut the engine off i hear no overheating symptoms. Any help appreciated. Thanx
Old Aug 16, 2011 | 06:30 AM
ex-x-fire's Avatar
Re: 3rd gen ls1 overheating
Does it just get hot going down the road & not when idling? If so I'd check the air dam & make sure the air is going through the radiator & not around it (like missing deflectors).
Old Aug 17, 2011 | 12:18 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
I agree with checking the air dams, could also be a stuck closed or stuck mostly closed thermostat.
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
jbd1969
Aug 17, 2015 07:06 PM
reiderz iroc
Aug 13, 2015 04:57 PM
