Aluminum Radiator Help
Old Sep 16, 2011 | 12:41 PM
meso5012's Avatar
Car: '04 Ram Hemi & '86 Camaro
Engine: 327 bored to 355
Axle/Gears: 323 posi
Should I ground my 2 core aluminum radiator? It will be secured in place with rubber radiator bushings top and bottom.
Old Sep 16, 2011 | 01:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Aluminum Radiator Help
It wouldn't hurt if you did.
Old Sep 17, 2011 | 12:22 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
What would be the need for a ground?
Old Sep 17, 2011 | 08:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Without a ground strap if the radiator ever became electrically charged for any reason it would set up a current to ground through the coolant which would cause electrolysis and rapid corrosion.
Old Sep 18, 2011 | 12:17 PM
Car: 91 z28
Transmission: 4L60e
Interesting, never thought of that.
Old Sep 19, 2011 | 07:15 AM
meso5012's Avatar
They say there is a small amount of electrolysis in every cooling system...distilled or de-ionized water should be used and ground the aluminum tank or it will corrode very quickly. Wasn't sure how true that was so I figured I would ask in a thread. Thanks for the info Apeiron.
Old Sep 20, 2011 | 10:54 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
He is right, electrolysis does occur no matter what you do but distilled water and most additives prevent it. I don't know if a ground would help since the water would be a good ground. A 50/50 antifreeze mixture helps also and raises the boiling point which aids in cooling as long as your cap is good. I have samco hoses on one of my other cars has anyone ever found any for our cars? They last virtually forever and you don't have to worry about them ruptureing.
Old Sep 20, 2011 | 02:44 PM
meso5012's Avatar
The impurities in the water is what allows electrical current to flow through it...take out the impurities and you reduce if not completely stop the ability for current to flow through depending on how clean the water is. Luckily we have a DI system at work for rinsing parts so that will be easy to get. I will probably still install a ground just for added protection.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
