need help on which accumulator dryer to buy
I need to replace my accumulator dryer and orifice tube, when I check rockauto they list 2 different acdelco dryers. They both say OEM replacement but one says "2 doors".....do I get the 2 door or other one?
86 camaro iroc auto 305tpi
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: need help on which accumulator dryer to buy
Four Seasons part # 33198
http://www.4s.com/Online%20Catalogs-...g/Content.aspx
Orifice tube is part #38623.
Thanks, is that a good brand reliable brand?
aside from the compressor, what other parts would you recommend buying (part numbers too please)
I'm staying R12
I'm staying R12
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Four Seasons isn't the cheapest, but quality is top notch. If you are changing the compressor, accumulator and O tube are a must. And if you are re-using the evap and condenser, make sure you flush them. If the compressor crapped out, there will be residual aluminum bits in there. Your old O tube will show you what's in the system.
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
