CSR electric water pump
Old Sep 23, 2011 | 03:10 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
I just bought a CSR electric water pump for a sbc. I just wanted to see what guys are doing to run them.. Should I be using some kind of relay and power it seperate with a swtch, or can i wire it in somewhere in the fuse box to power on when the key is on? Any help would be great Thanks.
Old Sep 23, 2011 | 09:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: CSR electric water pump
relay and a on/off switch for it. The water pump should have wiring suggestions in directions
Old Sep 24, 2011 | 01:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I just received a proform electric pump today, and it had no instructions. I am going to wire it into a 30amp relay and tie it into my holley hp efi ecu for power once ignition is on, along with my dual fans on the radiator.
Old Sep 24, 2011 | 07:23 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Thanks for the replys.. Not to get off subject but how is that new HP ecu?
Old Sep 24, 2011 | 12:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I love the thing, I can hop into my car, fire it up and drive off like stock. Except I am far from stock. HP EFI has so many little tricks you can wire it up for as well. I think there is a total of four i/o's you can use for whatever. I use one for a shift light, one for fan/waterpump on off. It is configured to be on with ignition, off for cranking, then back on once engine is running.
I am saving another i/o wire for the meth injection.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
