What amp fuse to use for cooling fan motor?
Old Oct 8, 2011 | 05:57 PM
zwanboy104's Avatar
Car: 1986 Trans Am
2 months ago I had a new cooling fan motor installed on my '86 Trans Am. Today, a fuse blew out and made the fan stop running. I noticied that the fuse was only a 20 amp fuse. Is this correct? Should I be using a 30 amp fuse? Thanks.
Old Oct 13, 2011 | 10:47 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Twenty Is Plenty
20 is fine for all stock types of fans.
If the fuse keeps blowing install a 25 amp fuse for the 20, then install a 20 amp fuse as close to the fan as possible.
Now if one blows it will help with diagnosis.
Happy Racing!
I’ll Bump You Once To Move Over, Next Time I’ll Spin You
Old Oct 13, 2011 | 02:40 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Re: Twenty Is Plenty
Thanks for the info!!!!
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Leggman1
Aug 6, 2015 04:15 AM
