Whats a good on off temp for single elec fan?
Old Oct 10, 2011 | 01:29 PM
jb1's Avatar
jb1
I have a stock 1986 305 TPI Automatic, and it has a 180deg thermostat.
What would be a a good fan enable and disable temperature for this?
Old Oct 10, 2011 | 10:28 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Whats a good on off temp for single elec fan?
185-190 on, 170 off
Old Oct 12, 2011 | 02:56 PM
RAS's Avatar
RAS
What he /\ said.
Old Oct 12, 2011 | 04:41 PM
torque_is_good's Avatar
180 thermo....
200-210 on, 190-185 off
hmm
that conflicts with the other 2 but you did say a 180 thermostat
Old Oct 12, 2011 | 06:08 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I have a 180* stat on 305 TPI. Fan switch is 211* on, not sure what the off is, but it's about 190*. After experimenting with a few, this one is perfect, it only runs in traffic. If you go any lower the fan will run a lot more than it needs to.
Old Oct 13, 2011 | 10:39 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Hey eseibel, do you have a part number for that 211*?
Old Oct 13, 2011 | 11:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by UnderCover89TBI
185-190 on, 170 off
If you go with this, the fan will never shut off once on.
Most fan switches (the screw into the block OE style) have a roughly 10° temp swing. Autozone sw505 is a 215°F on fan switch. 'perfect' for a stock motor. The ECM (TPI, v6) controlled fans were set to run at 220°F.
There is little to no benefit to running any cooler thermostat on a stock motor.
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
