AC compressor won't stop
Old Jan 21, 2005 | 02:42 AM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
Whenever my heater control is on anything but off, the ac clutch continually kicks on and off. When I use the defrost I can see the clutch kick on for a couple seconds then off. What is causing this?
Old Jan 21, 2005 | 10:11 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the refrigerant pressure, if it is low the compressor clutch will continue to fluctuate like you are mentioning. I had this problem during the summer and found I had virtually no refrigerant in the system. I took the system apart, cleaned everything good and converted over to R134A. After servicing the system everything has worked fine.
Old Oct 13, 2011 | 08:50 PM
thecraze's Avatar
Re: AC compressor won't stop
What if the compressor just kicks on and stays on? Mine is doing that when I turn the heater on.
Old Oct 13, 2011 | 11:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That's what is what it should do. The compressor running isn't dictated by the temp selector. It (a/c compressor) will run when set to max, norm, bi-level or defrost.
(yes, I know this is a resurrected post)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
camarohelp
Sep 22, 2015 03:19 PM
Fronzizzle
Sep 8, 2015 12:10 PM
