Coolant leak from sensor on back of manifold, 5.0 TBI Help!!
Old Dec 1, 2011 | 02:18 AM
5speed88's Avatar
Car: 1988 Sport Coupe
Engine: 5.0 TBI
Transmission: 5 Speed
Axle/Gears: 3.08 Posi
I feel dumb for asking this, but after searches, i still cant figure out what sensor is plugged into the back of my intake manifold. its on the passenger side at the very back of my intake manifold, right next to my dizzy. i didnt notice the leak until i changed my valve cover gaskets, but its leaking bad from the looks of it.
So what is this plug? is it just a coolant temperature sensor or something else??
thirdgen has always helped with my car, i hope this time is no different
Old Dec 1, 2011 | 07:37 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Coolant leak from sensor on back of manifold, 5.0 TBI Help!!
Sounds like that is where the fitting for the heater hose that goes to the heater bypass valve should be. What is there now?
Old Dec 1, 2011 | 08:39 PM
5speed88's Avatar
Engine: 5.0 TBI
im not sure what it is, one of the hoses coming from the heater valve goes to this mystery plug. Its at the veeery back of my manifold, almost right underneath my dizzy.
Old Dec 1, 2011 | 08:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, that's what should be there. It's threaded into the manifold and is either loose or has damaged threads that would cause a leak. You will have to probably take off the air cleaner to check it out or tighten it up without doing too much stretching.You will probably have some water spillage, but not too much. Have fun!
Old Dec 1, 2011 | 08:54 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
its more then likely u just need some pm and up keep make sure all your hoses and clamps are good then go from there
Old Dec 1, 2011 | 09:01 PM
5speed88's Avatar
Engine: 5.0 TBI
Ok, well at least i know it shud be there. but what is it? if its just a coolant temp sensor then ill just replace it cuz its rusty as hell. i already tried to tighten it but more coolant just found its way out.
Old Dec 2, 2011 | 02:03 PM
5speed88's Avatar
Engine: 5.0 TBI
BUMP
Old Dec 2, 2011 | 02:34 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's just a hose fitting with threads. Sounds like somebody substituted in a cheapo replacement that doesn't fit right. Should be easy to get, or I may have an extra if you can't find one. No sensor involved, just provides a place to attach the hose. I'm assuming the hose and clamp are good, yes?
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
Randomtask2
Aug 13, 2015 01:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
timonator
Aug 11, 2015 09:56 PM
