Primary Fan comes on too soon, '88 GTA
Old Dec 10, 2011 | 01:24 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
While searching threads for cooling fan issues, I found this semi-recent post:
Originally Posted by deadbird
If both fans are running with the A/C, the fan circuits are working. '87 and older, the A/C only kicked on the single (or primary in dual fan cars).
Since you're is '89, both fans run with A/C
<b>The ECM should turn the primary on at 220°F
The fan switch should turn both (like the A/C) fans on at 238°F in the event the ECM does not kick the primary on.
It is not uncommon for the stock gauge to be off slightly.
It is not uncommon for the ECM to read a different temperature from the gauge due to the sensor/sender locations.
There may be an issue with the ECM fan driver. </b>
Jumping the ALDL A-B terminal (flashing check engine codes) with the KOEO (key on engine off), should make the ECM run the primary fan. If not, the ECM isn't controlling the primary fan.
Unplug the fan switch and ground the wire KOEO, it should make the fans run as well.
It seems a bit odd the ECM and fan switch have both failed.
The driver side fan comes on within a few minutes of the engine being started up cold even in this cold weather. I replaced the CTS (that goes into the intake manifold) a few weeks ago, and the symptoms have stayed the same. Since the ECM controls the primary fan, what should I check next? How can the ECM fan driver be tested?
My gauge has not gotten up to 210ish in a long time, so the quickness of the fan to come on combined with the low gauge reading seems to indicate the fan is clearly coming on too soon.
Old Dec 10, 2011 | 02:06 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Primary Fan comes on too soon, '88 GTA
have you verified that the temp gauge is accurate? it could be that the pri fan is comming at at the right engine temp but the gauge is off.
Old Dec 10, 2011 | 03:28 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
I used to drag race with the occasional data logging. If the ECM temp was correct, at an indicated 212F gauge, the ECM displayed 232F. I just disconnected the primary fan and drove it around. It would barely get 1/4 up while moving. It took several minutes idling and some 2K revs to get the gauge to 212F. Though I don't know for certain, I think the gauge is accurate because the fan comes on so soon. It came on within 3-4 minutes and the outside temp was 40F.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
