leak
Old Jan 13, 2012 | 06:27 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
leak
what are all the places coolent can leak from the front of the block
Old Jan 13, 2012 | 07:29 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: leak
Water pump.
Old Jan 13, 2012 | 07:35 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
thats the only plave cause i have a magor leak
Old Jan 13, 2012 | 09:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: leak
This is the time of year for the water pumps and hoses to blow.And batteries.
Old Jan 13, 2012 | 09:54 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
Yeah my battery's pretty much fryed But your saying it's safe to assume its the pump cause I can't find anything else
Old Jan 13, 2012 | 10:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: leak
Most likely if you say it's defiantly coming from the front of the engine.Check it,start it up and wait for it to leak. .
Old Jan 13, 2012 | 10:07 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
its deff coming from the front it dosent even need to start it just poors out
Old Jan 13, 2012 | 10:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: leak
Just pours out!!!!check you lower hose first,if that's ok your pumps shot
Old Jan 13, 2012 | 10:17 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
ok ehh to cold and snowy to check right now ill do it tomorrow if i get a chance but thanks for the intell
Old Jan 15, 2012 | 09:51 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: leak
are talking about the very front of the engine, where the timing cover is? only things there for the colant system is the pump and the upper and lower rad hoses or the radiator. if its just pouring out its probably the lower hose or the radiator.
Old Jan 15, 2012 | 02:43 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
Yeah the front of the block But it's no where near the rad
Old Jan 15, 2012 | 02:50 PM
travis401's Avatar
Car: 91 Camaro RS
Re: leak
have you checked to make sure you dont have a cracked block or a freeze plug that poped?
Old Jan 15, 2012 | 03:21 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
No I have not checked yet due to imclamet weather
Old Jan 17, 2012 | 10:18 AM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
so i went out there to find the leak and well its not there any more
Old Jan 17, 2012 | 01:36 PM
travis401's Avatar
Car: 91 Camaro RS
Re: leak
massive leaks like you were describing done fix themselves.
Old Jan 17, 2012 | 02:08 PM
bronzeken's Avatar
Car: 86 camaro
Engine: 305 carb
Re: leak
i know man when it was there half my coolent poored out on to the floor and today i went out to the garage filled it up and nothing poured out every thing still in the place it should be im so confused
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
