pressure cycling switch adj
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
when i convert my 86s ac to 134a how many turns out from seated do i adj my pressure cycling switch?? what ,if any, other things do i need to do for the conversion??
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: pressure cycling switch adj
you dont adjust your pressure cycle switch. your o-rings should be compatible but a/c o-ring kits and a receiver drier are fairly cheap on ebay. Thread
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
