Engine Cooling - Fans
Old Feb 13, 2012 | 08:16 PM
Mel.J's Avatar
Hi everyone,
I own a 1988 Pontiac Trans Am GTA, I have recently encountered cooling problems due to the fans not working properly. I had it checked at the mechanic and the engine for one of the existing two fans was rebuilt. I have not encountered overheating problems or any problem what so ever related to heating!
My question is, shouln't both fans work at the same time or even at separate times? I only seem to see one of them work, can't remember seeing the other work!
P.S. i would appreciate it if you guys could help out as i live overseas and mechanics seem to know as much i do!!
Thank you
Old Feb 17, 2012 | 11:33 PM
73Mike's Avatar
Car: '92 Z28 Vert Z03
Engine: 305tpi
Transmission: 5 Speed
Axle/Gears: 3.08 Posi
Re: Engine Cooling - Fans
From one of the Tech Articles...
General Motors engineered these cars to run HOT!! The primary coolant fan does not engage
until 222° F or higher (depending on year and engine) and the secondary fan until 243° F! It’s
been shown that at these high temperatures, air and fuel burn more completely and therefore
producing less hydrocarbons.
https://www.thirdgen.org/electric_co..._spec_mod_dual
Old Feb 18, 2012 | 08:17 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The 2 fans are independent. Primary is controlled by the ECM, secondary is controlled by a switch in the passenger side head. Change that switch in the head to Standard Motor Products part #TS85, and the secondary fan will come on at a more reasonable 211 degrees. That will make it come on after sitting at a red light for a few minutes, then it will turn off shortly after you get underway. Perfect.
Old Mar 6, 2012 | 09:58 PM
Mr.RiverRat's Avatar
I own a 1990 c1500 tbi 350 it has a clutch fan I was wanting to get rid of it and get electric one bc of all that excess noise. Anyone have a idea of what size or cfm I'll need for this swap. Or if any universal one will fit? Any feed back is greatly appreciated!
eightsixseven
Dec 16, 2024 01:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
