Removing Fan from Motor
Old Mar 6, 2012 | 05:26 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Does anyone know the procedure to remove the fan blades from the fan motor? They are reverse threads, but how do you hold the motor shaft from spinning while turning the fan blade retention nut? There doesn't appear to be an indexing hole to hold the motor shaft from rotating.
Thanks for your help.
Attached Thumbnails Removing Fan from Motor-img_0049.jpg   Removing Fan from Motor-img_0050.jpg
Old Mar 6, 2012 | 06:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Removing Fan from Motor
grab venturi ring, use wrench to remove nut, pull.
Attached Thumbnails Removing Fan from Motor-img0340a.jpg   Removing Fan from Motor-img0341a.jpg
Old Mar 6, 2012 | 06:38 PM
85FBTranam's Avatar
Tried that, but the the shaft still spins. Possibility that the little tabs behind the "venturei ring" are snapped off, so there is no restriction to the shaft?
The shaft nuts are pretty rusted too, so tried a penetrating oil with an impact. No luck.
Old Mar 6, 2012 | 07:33 PM
deadbird's Avatar
Engine: TPI 305/ v6
The venturi ring is what I'm holding. I don't recall if the single fans just have a key way (flat spot) on the motor shaft. My dual fans have the hub as shown.
Assuming you're doing this because the motor is shot, I'd probably try drilling the motor casing (not sure how well magnets drill) an into the armature to pin it with a screwdriver/bolt.
Old Mar 6, 2012 | 07:35 PM
85FBTranam's Avatar
I think it is the same set up as yours...dual fan set up. Just trying to dismantle and clean them up. I appreciate your time.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
mhatfield 14
Aug 15, 2015 10:47 AM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
