only drivers side fan works
Old Mar 19, 2012 | 05:50 PM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
I changed out the thermostat today in my car. It was nothing like working on my 80 Z28. I changed out the thermostat in that car in 20 minutes. Anyway, I let the car run and get up to temp. It took about 10-15 minutes and when the needle hit 240 the drivers side fan kicked on and the temp held right there. I got in the car and turned on the a/c and the passenger side fan did nothing. Now, I did notice the compressor did not come on (arrrrrrrrggggggghhhhhhhhh!!!!!!!!) but that is for another day. Will the fan not kick on if the compressor does not kick on? I'd kind of like both of them to run regardless if the a/c is on. What is the trick for that? I'm going to change out the fan switch for a cooler one this weekend. Thanks in advance.
Old Mar 26, 2012 | 12:33 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: only drivers side fan works
https://www.thirdgen.org/forums/cool...-switches.html
Old Mar 28, 2012 | 12:13 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Ask VINNEY
Depends on the VIN.
On your car most likely that fan turns on
(among other ways) when the AC head pressure >230.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Mar 28, 2012 | 12:34 PM
88gunmetalgta's Avatar
Wouldn't the AC pressure kick on the drivers side fan only anyway? In my '88 TA the passenger side fan is only controlled by the temp switch in the head.
Old Mar 28, 2012 | 01:27 PM
NINÅ's Avatar
Transmission: 765R4
Ask VINNEY
Depending on VIN the left or right fan is controlled by the AC.
Anyway his problem is even when the engine is 240°, and the AC is requested, he still has only one fan running.
Happy Racing!
Old Mar 29, 2012 | 04:43 PM
Damon23's Avatar
Car: 1992 Z28
My A/C is low. What in the VIN denotes how the fan operates?
Old Apr 2, 2012 | 09:28 AM
LeadFoot88's Avatar
Car: 87 IROC-Z
Engine: LB9
Axle/Gears: 3.08
Just hard wire the fans to both turn on at the same time. That is what I ended up doing on my old 88 305, it ran 10x better.
Old Apr 14, 2012 | 03:41 PM
SoTexZ28's Avatar
Car: 88 Camaro IROC-Z Convertible
Transmission: 700R
Lead Foot, how did you "hard wire" both fans? I've been wanting to do that, being that I need both fans on 99 percent of the times in this South Texas sun. For now, I've had to run the A/C in order for both fans to run, the one that is suppose to turn on by itself is not working.
Old Apr 14, 2012 | 05:26 PM
LeadFoot88's Avatar
Car: 87 IROC-Z
Engine: LB9
Axle/Gears: 3.08
I wish I was home and had a picture to show you how I did it. But I am about 7,300 miles from my baby right now, haha. Maybe someone else can chip in on how to do it. Pretty easy though, I believe I just tapped the A/C fans pos and neg into the driver side one. I tried searching the forums just now, but no luck on finding pictures on anyone else doing it.
Old Apr 15, 2012 | 09:39 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Read my signature for details on how and when the fan comes on.
The passenger fan will rarely come on due to temperature alone as it starts higher up than the driver side one does.....It also turns on and off due to A/C high side pressure. If your A/C is low, it won't build up enough pressure to turn on the passenger fan.
This time of year, my passenger will cycle on and off when the A/C is turned on. In summertime, the passenger fan will stay on when the A/C is turned on. Both cases being in "cold start" modes with a cold engine. Has to do with the ambient temperature and what the condenser is dealing with.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
