Trans cooling
Car: 86 T/A GTA Rims
Engine: 350 Mild cam 750 holly
Transmission: Beefed 700R4
Trans cooling
Just put in a trans cooler... should i run it with the radiator or just the trans cooler? I already hosed it just to the trans cooler... will it be fine that way?
Thank You
Thank You
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Re: Trans cooling
If you will be driving in only warm weather then just through the trans cooler is fine. Otherwise run it through the radiator too.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Trans cooling
I watched one of the hotrod shows years ago and an expert stated that for every 10 degrees you drop in trans temp you add ten thousand miles. Heat is the number one enemy of an automatic trans.
