Buy Air Dam but still OVERHEAT!
Old Feb 1, 2012 | 10:24 AM
olveracm's Avatar
Car: 88 Firebird WS6 red
Engine: 305 TBI
Hey guys so i bought the air dam and it still over heated..
Drive on the freeway, hit 60MPH and it reached 3/4th of the gauge.
So I got out oh the free and it cooled down a little.
I'm lost. I don't know wat to do?
Old Feb 1, 2012 | 10:32 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Buy Air Dam but still OVERHEAT!
Things to check:Thermostat...Water pump...Upper radiator hose
Failure (partial or full) of any one of those can contribute to overheating too.
Old Feb 1, 2012 | 11:45 AM
olveracm's Avatar
Engine: 305 TBI
New thermostat
New hoses.
Should i check the radiator and see I'd it holds up pressure?
Old Feb 1, 2012 | 11:49 AM
Car: GTA
If it isn't holding pressure, that would most likely be a bad radiator cap (i think).
Old Feb 1, 2012 | 06:45 PM
Mac10's Avatar
Check the easy stuff first . like have the cap off while it's running making sure the coolant is all the way to the top . Maybe your rad is clogged , is the rad full of sludge . Make sure your oil isn't low , ect . Could be air bubbles in the cooling system . I think when the engines get old they tend to heat up more , the weight of your oil filter when changing your old can say a lot about the condition of your engine . If none of that works try swearing
Old Feb 7, 2012 | 06:36 AM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
I was having this same trouble with my 87 5.7 right before the heater core went bad. The thing is, the radiator was rusting and, pushing debris through the system. The over heating stopped after changing the heater core but, I went the distance and replaced the entire cooling system (minus the fans). Hasn't even got close to over heating since.
Old Feb 7, 2012 | 09:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Make sure your rad surface is clean and the fins are free from dirt and stuff. Also check the timing.
Old Feb 8, 2012 | 01:04 PM
olveracm's Avatar
Engine: 305 TBI
i figured it out it was the timming, i fixed it and it ran way better then before, but it still reaches the red line and after a couple of mins it cools down to 1/4 of gauge.. what do u think it it??
i might need to add new colant/
Old Feb 8, 2012 | 02:33 PM
hilltop530's Avatar
Engine: 5.7 TPI
how does the water in the radiator look? Also, what kind of coolant are you using?
I know this is something nobody wants to hear but, check your oil and water frequently, your symptoms are similar to a small leak in the head gasket. If you're not leaking water visibly but, are still having to put more water in a couple times a week, it could be a gasket.
Old Feb 8, 2012 | 11:00 PM
olveracm's Avatar
Engine: 305 TBI
it looks dark but It hasn't been changed And I will change it soon.. and yeah I have checked them.. I think it is fine.. but I could be wrong u know..
but It runs and starts fine. no rough idle or lag.
Old Feb 9, 2012 | 02:48 PM
Cosmik Debris's Avatar
Fans? Do they come on?
Old Feb 10, 2012 | 10:23 AM
olveracm's Avatar
Engine: 305 TBI
Yes they do
but I did figure it out.
It was the coolant.
I think the mixture was more water then coolant and the water was getting hot to fast.
I flushed it out and drained the water out and added new coolant
Old Feb 10, 2012 | 11:11 AM
TTOP350's Avatar
Its really better to have more water than coolant. It may have been very old and needing changed or the flush cleaned it out. either way you have it fixed..
Old Feb 10, 2012 | 01:40 PM
olveracm's Avatar
Engine: 305 TBI
It was very old it was like dark and nasty... but Why is it better to have more water
Just wondering/
Old Mar 28, 2012 | 11:50 AM
olveracm's Avatar
Engine: 305 TBI
So I sold my firebird! it was fun while it lasted
Old Apr 1, 2012 | 12:39 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Water is the most effeciant coolant on the planet but the antifreeze raises the boiling point which of course helps a ton. Most people say a 50/50 mix but I like a 60/40 mix with a little water wetter or purple ice. Distilled water keeps the radiator and other parts of the system from corroding.
87iroctheo
Dec 4, 2016 11:47 AM
Wylecoyote08
Nov 6, 2015 03:46 PM
krisner89
Oct 10, 2015 06:03 AM
lakeffect2
Aug 23, 2015 08:44 AM
mustangman65_79
Aug 11, 2015 03:17 PM
