wire harness
Old Mar 31, 2012 | 07:58 PM
jerseyrich's Avatar
wire harness
I need to know what color wires go to ABCD on original lug socket!
Where can I find a wireing diagram for what color wires go to ABCD labled on socket?
Old Apr 1, 2012 | 01:19 AM
jerseyrich's Avatar
Re: wire harness
I realy need a diagram now scince im going to fix now... Cant slee over it!
Old Apr 1, 2012 | 02:59 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: wire harness
What year / model / engine, and what is the plug for?
Old Apr 2, 2012 | 10:58 PM
jerseyrich's Avatar
Re: wire harness
1985 TA 5.0 tpI Relay is mounted on radiator bracket on passenger side. I have new relay but plug harness was taken apart. Just need to know what wires go to the ABCD HARNESS. Or can someone send me a wire link for this harness!
Old Apr 3, 2012 | 11:28 AM
Re: wire harness
Ok, I'm on it. I have LOTS of wiring diagrams I collected while doing my projects, so let me look thru and see what I can find.
Old Apr 3, 2012 | 12:27 PM
Re: wire harness
Is it your cooling fan relay? That sounds like the proper location, but my '88 LB9 IROC-Z uses 2 relays in that location for the cooling fan, and they are both 6-socket style (ABCDEF), although only 4 are used, ADEF. A is Red, or the main 12V supply to the fan(s), B is empty, C is empty, D is Tan / Brown, or the 10A fused 12V supply to the inductor coil in the relay. E is Orange, or the 12v supply via fusible link to the switch side of the relay. F is Green, or the signal wire from the inductor coil side of the relay to the ECM.
If this isn't helpful, let me know and we'll try again. Start by letting me know what color wires you are dealing with, that is incredibly helpful towards identifying their circuit.
Old Apr 4, 2012 | 12:45 PM
jerseyrich's Avatar
Re: wire harness
Thanks very much! Exactly what I needed.
Old Apr 4, 2012 | 09:03 PM
jerseyrich's Avatar
Re: wire harness
I pluged wires as told & everything works perfect!
I went with aftermarket parts, But after owning the car 26 years I wanted to keep all original! Thanks again & thank you third gen. people who care....
jerseyrich
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
