Water temp gauge stuck straight up.
My water temp gauge seems to be stuck straight up all the time, key off, on, or engine running. Found similar posts, but not quite the same problem. Lifting sender wire at sender has no efffect, power to gauge, other gauges work. Car is not overheating, 89 IROC. Any ideas fellas?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Water temp gauge stuck straight up.
*edit - duh
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Have you unplugged the wire from the sending unit to see if that makes the gauge drop? if so then your sending unit is stuck in a permanent ground and needs to be replaced. Those gauges work off of resistance to ground and a pegged coolant gauge means somewhere that sensor wire is getting a full ground.
Car: '02 Z06
Engine: L33 5.7
Perhaps your gauge got pegged once and the needle got stuck. Remove your bezel and gently move the needle with your fingers.
Engine: TPI 305/ v6
Tmony... that's because I'm a dumb-ss and copied the search result url instead of the thread link
https://www.thirdgen.org/forums/cool...icks-past.html
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Same thing happen on mine - when you pull the bezel apart you'll see the needle slid over the edge of the gauge getting stuck. Just use a pair of small duckbull pliers and bend a little ledge/stop into the edge of your gauge for the needle to stop and come back around. Easy fix - wish they could all be this easy.
could you post a picture of this?
Ended up taking out the water temp gauge to do this. I used a cloth so It didnt damage the bezel but still ended up making some scuffs so I just black taped it and you cant even tell.
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
