AC stays on even when switched to Vent
Old Apr 18, 2012 | 12:13 PM
92GTA's Avatar
This is recent to my GTA the last couple summers and just started out of the blue. My AC seems to continue running even when I move the slider over to Vent.
Is this an issue with the contacts in side perhaps? Do I need to remove it from the radio pod, disassemble, and hit it with some contact cleaner?
Anyone else have this issue?
Old Jan 7, 2014 | 02:53 PM
92GTA's Avatar
Re: AC stays on even when switched to Vent
Bump. I'm ready to revisit this issue before spring.
Old Jan 8, 2014 | 03:16 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
It will definitely be in your head unit.. the mode selector has a rotary switch laid horizontal that bridges ac clutch connections in certain modes. sounds like either the contacts fused or melted. Pull the head unit, and run a continuity test between pin 1(lt grn) and 2(brown). In MAX, NORM, and DEF, should have 0.0 ohms. In all other modes, should be open (0.L)
Old Jan 8, 2014 | 06:03 PM
92GTA's Avatar
You are awesome! That's exactly the kinda info I was hoping for!
Thank you!!
Alex
db057
Apr 28, 2019 07:45 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
luvofjah
Sep 3, 2015 07:08 PM
