smoke or steam coming through dash vents
Old Aug 2, 2012 | 10:39 AM
Wayne91rs's Avatar
1991 camaro carbed 350
I have what seems to be smoke or steam coming through my vents when I accelerate. Or when I go up a hill. The smell is disgusting as well and its fogged up the inside of my windshield. The car doesn't overheat. And it doesn't have ac. What could be the problem? I'm thinking heater core but the floor in my car isn't wet. Just confused here all the help will be greatly appreciated.
Thanks!!
Old Aug 2, 2012 | 11:08 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: smoke or steam coming through dash vents
clean out the cowl vents. they tent to clog with stuff. all so check your blower motor. i had that issue in my truck and i turned out the blower was shorting out and making a mess. and as you said... check the core.
Old Aug 4, 2012 | 10:34 AM
82RZ's Avatar
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Good advice, if the cleaning doesn't help - its heater core replacement time.
Old Aug 4, 2012 | 10:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Wayne91rs
I have what seems to be smoke or steam coming through my vents....The smell is disgusting as well and its fogged up the inside of my windshield.
Classic heater core symptoms. Coolant is going somewhere or will be. I'd drop the kick panel and take a peek.
JamesC
Old Aug 5, 2012 | 05:57 PM
Wayne91rs's Avatar
Well I replaced the Heater core and it still smoking. Not as bad but its still does it. I even ran the heat as well turns out I only have defrost high and low. Any ideas now? Did I miss something?
Old Aug 6, 2012 | 08:57 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Check all the vacuum lines for the air controls.
chazman
Aug 28, 2018 03:25 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
lakeffect2
Aug 23, 2015 08:44 AM
chazman
Aug 22, 2015 02:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
