factory a.c or removed???
Old Aug 6, 2012 | 06:43 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i was giving my car an overhaul last week and was wondering if my 85 iroc came with a.c or not... i see the controls for hot/cold but my engine bay looks different... not sure if im missing the smog pump or that silver can on the left??? it was last inspected in 2010 so im not sure if the smog pump was deleted before or after or if it even had one... also, i dont see cut hoses or brackets for that silver orvice (i t hink that what it is..) when i turn the cool controls to high its blows cool air, no ac cod but cool... havent tried it while driving...
heres some pics:
Attached Thumbnails factory a.c or removed???-ac1.jpg   factory a.c or removed???-ac3.jpg   factory a.c or removed???-ac4.jpg
Old Aug 6, 2012 | 06:44 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Re: factory a.c or removed???
engine bay:
Attached Thumbnails factory a.c or removed???-bay1.jpg   factory a.c or removed???-bay3.jpg   factory a.c or removed???-bay5.jpg
Old Aug 6, 2012 | 07:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Those are the factory controls for a car W/O AC, and there's no signs of any unit having been there under the hood either, but people change things. You would have to check the RPO codes to know what it came with from the factory.
Old Aug 6, 2012 | 07:14 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yeah, im gonna rpo's tomorrow...
thanks...
Old Aug 6, 2012 | 07:16 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
so where does the cool air come from? i know its not gonna blow cold ac but what about summer driving...??? will it blow cool air like a fan or just inake outside air and cool it for the cabin???
Old Aug 6, 2012 | 08:27 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You do not have A/C. When set on cold, the vents will blow air that is the exact temperature that the air is outside at base of the windshield.
Old Aug 7, 2012 | 05:08 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
dam! im gonna be roasting with the t tops off! its been 90 degrees all summer here in pittsburgh, pa!!! oh well, thanks
Old Aug 7, 2012 | 11:11 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
As Henry mentioned.....
Here is a link of the factory A/C & Heater controls for your car (if your car originally came equipped w/air conditioning):
http://www.ebay.com/itm/82-89-CAMARO...#ht_1572wt_922
Old Aug 7, 2012 | 01:45 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, thnx, those controls are on my other iroc that has a.c
Old Aug 8, 2012 | 08:03 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i might buy a universal kit from an ac company like classic air....
i think its a shame that our cars are almost 30 years and there still isnt a kit available for us... no one make ac kits for 3rd gens
Old Aug 9, 2012 | 11:39 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can someone put a list off the components i need to add air??
then i can search the parts wanted section...
thanks
Old Jan 19, 2013 | 06:40 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
should i be getting heat when i have the switch all the way to the right?
i started the car and put it on full blast but it never gets hot????
Old Jan 27, 2014 | 11:23 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Old May 22, 2014 | 02:44 PM
JonM's Avatar
common causes, but not the only ones, stopped up heater core, low radiator fluid so hot fluid isn't making it to the core.
if the heater core was leaking badly enough to stop it from heating you would have the smell of hot fluid in the car wet floor boards or fluid in a puddle under the car.
not changing and flushing fluid often enough will plug up a core or eat it up when the coolant degrades enough
Old May 22, 2014 | 02:50 PM
Joe Tag's Avatar
Probably a little late on the reply. He will be looking for the A/C parts again by now.
Old May 22, 2014 | 03:22 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Looks like you will need everything from the a/c condenser to the control head and everything in-between... Find a donor car.
Old May 22, 2014 | 07:14 PM
JonM's Avatar
yeah i know i saw it when i was looking for info and it is a common question and might help someone else
Old Apr 14, 2021 | 02:14 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
finally getting the car ready, need the a.c back in service. besides a donor car, does any one make kits or universal kits that will fit our cars? also will factory a.c work with ls3 upgrade? i need pointed in the right direction, thanks
Old Apr 15, 2021 | 04:32 AM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
1) Yes they do. 2) Not familiar with how the LS3 mounts the compressors, (sorry). 3) -----------------> Google/thirdgen search function for LS swaps.
Bralgar
Nov 13, 2010 09:36 AM
Billd
Fabrication
Mar 26, 2010 07:56 PM
oldblueZ
Sep 4, 2003 02:04 AM
V6camaroman
Feb 25, 2003 02:13 PM
89BlueTA
Feb 17, 2002 11:50 AM
