Thinking about replacing Water Pump and Radiator.......??1
Old Aug 20, 2012 | 11:16 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got my 84 Z28 5-speed, and I believe my water pump has gone bad on it since I am hearing it kinda rattle when i turn on the car, and I was also wondering on wether or not I should replace the radiator, its kinda rusty in the inside, but I just arent sure on wether I shuld drop more money onto replacing it....and if so anyone got any suggestions for the best bang for my buck as in water pumps and radiator...my budget is prov $200 for both of them, thanks....I am a college student as well...
Old Aug 20, 2012 | 11:58 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Thinking about replacing Water Pump and Radiator.......??1
Brand new water pump no reman! Mine went out and what a difference it made once it was fixed. Not only that the reman need modifying I think it was going out for a while. So is there play in the pulley on the water pump? Is there vibration when you put a long tool to it? Is the car over heating? Is that why you want to replace the Radiator? Might be something else. Depending on what is going on with the car.
Old Aug 21, 2012 | 11:31 AM
calgutie's Avatar
Car: 1984 Z28
well when the reaosn as to why i wanna replace the water pump is becuase I am hearing noises coming from it, and also my car is voerheating when i go through the N N OUT drive through LOL......and in traffic and I know its overheating because the radiator fluid comes out super hot to the overflow can.
Old Aug 21, 2012 | 12:18 PM
ex-x-fire's Avatar
Rent a cooling system pressure tester a autozone, find the leak.
Remove the belts & feel the w/p, alt, air pump, ect for loose bearings or rough when turning them.
Old Aug 21, 2012 | 12:23 PM
calgutie's Avatar
Car: 1984 Z28
hmmm....i see.....but physically that water pump looks pretty bad compared to the other things i have under the hood, even the end where the hose is connected is pretty darn rusted.
Old Aug 21, 2012 | 03:05 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Try a new radiator cap first. It should be routinely replaced and as it fails, it will allow the overflow tank to fail below rated pressure.
New water pump and new radiator can be had for under $200. When the water pump fails it will begin to seep coolant from the weep hole under the snout.
midge54
Jan 29, 2017 07:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
