AC delete box question
Old Aug 29, 2012 | 11:41 AM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
I didnt realy know where to put this but anyway I see delete boxes for sale that look like they use the existing fan motor? Then I see threads saying you cant use the AC motor/fan. Someone please enlighten me on this
Old Aug 30, 2012 | 07:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: AC delete box question
You cant reuse your existing a/c/heat fan because the fan cage is thinner on the delete box to account for it being closer to the firewall.
Old Aug 30, 2012 | 08:52 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Someone correct me if im wrong but i think you can use the old motor but you need the AC delete fan cage (mouse wheel) for the reason said above.
Old Aug 30, 2012 | 10:20 PM
Z06 FAN's Avatar
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
I went to the junk yard and got one from a 92 S10 with the motor & fan cage for $20. Took it home and sanded and painted it up like new. Looked on my buddys non air iroc and it was the exact same as his factory box. Works perfect! looks factory!
Old Aug 30, 2012 | 10:56 PM
YEAHUNO's Avatar
Car: 91 Z28
Engine: 357 sbc
I have a question regarding the a/c delete fan box. How do u wire it up?!?! It came with the 91 z28 project I got. Engine wiring harness was already cut (everything on passenger side) all wires on driver side look like stock length. Please help. Color or connectors? I would it to work. Thanx.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
