where can I buy a radiator hose spring
Old Aug 29, 2012 | 09:53 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Axle/Gears: 3.42 w/posi & disc brake
Does anyone know where I can buy a radiator hose spring?
Ive googled and searched this site but its been almost an hour and im not getting anywhere.
Thanks for the help
Old Aug 29, 2012 | 11:54 PM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
Re: where can I buy a radiator hose spring
I'm not aware of anyone that sells them. They are usually just in hoses that need them and come with the hose. Why do you need a spring by its self?
Old Aug 30, 2012 | 05:55 AM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Yeah, my lower rad hosse is collapsing under throttle
Old Aug 30, 2012 | 07:02 AM
Just replace the hose.
Old Aug 30, 2012 | 07:09 AM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
I did and it still has the same problem. I thought it was just a tired hose so i bought a new one but the new one collapses too.
Old Aug 30, 2012 | 09:53 PM
dstss's Avatar
Engine: 5.0 TPI
Try replacing the radiator cap. Know it sounds unlikely but the cap is designed to let coolant flow back and forth to the overflow bottle. If it is stuck or the overflow is blocked, you are creating a vacuum at throttle with no release. Easiest thing to try before getting more creative.
Old Aug 31, 2012 | 09:04 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Most neglected cooling system part is the radiator cap IMO.
Old Sep 21, 2012 | 01:20 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
For the record, I changed the radiator cap and I still had the same problem. After alot of searching I came across a thread and some guys on it said that there are two types of hoses now (one thats better quality and wont collapse and the other is a pos). If I remember correctly, Napa sells the good ridged hose.
I fixed my problem with two radiator hose springs that are ment for a SBF. One spring wasnt long enough so I ordered two. I have more faith in these springs than the ridged hoses but thats just me.
I hope this helps someone.
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 20, 2015 12:29 AM
Zachattack0925
Aug 12, 2015 09:52 PM
