Low Temperature Reading
Old Sep 16, 2012 | 02:22 PM
TW89FB's Avatar
Car: 1989 Firebird
Engine: 2.8 Litre V6
Transmission: 4 Speed Auto
Hi
Wonder if any one can help me - when I first start the car (from cold) the temperature gage slowly climbs as you would expect to mid point between 100 and 220. However once it reaches running temperature it drops down again to just above 100.
Also I there is very hot air coming through the vents when switched to hot / heater etc.
Could both of these be due a faulty thermostat?
Old Sep 16, 2012 | 05:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Low Temperature Reading
The temperature dropping like that is the thermostat opening. After that the temps will slowly go back up to normal operating temps
GTAman
Mar 15, 2019 11:40 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
