New 3 core, 4th gen fans, hoses, tstat... still rising
Old Sep 19, 2012 | 04:28 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Ok so on my 88 IROC 350 car, I just put a new Victory 3 core rad in, had the 4th gen fans for awhile (they work great), new 160* tstat, and upper & lower hoses replaced w/in the last 10 months or so... Air dam is intact (one very small slit in the middle but it doesnt effect operation.
When I idol, w/ or w/o AC on, it stays in the 160-170 range. When I get much about 30 mph, the temp starts rising and wont cool back down until I come to a stop for a second. The only thing I can think of is that I'm missing some other under carriage plastics or that the pump is going out BUT can see the coolant PUMPING hard thru the rad. (The temp max's out around 220 or so but it should NOT be getting that high with the system that I have...)
This has be pretty stumped so opinions are welcome please...
Thanks,
Doc
Old Sep 19, 2012 | 11:22 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: New 3 core, 4th gen fans, hoses, tstat... still rising
Thanks,
Doc
That would be my guess as it cools no load/stationary w/fans.
Old Sep 20, 2012 | 08:32 AM
Car: 1988 Iroc-Z
Yea but why? I'm going to replace the h2o pump & put a 180* tstat in & see if that helps... Kinda at my end right now lol...
Old Sep 20, 2012 | 09:57 AM
87350IROC's Avatar
Car: 87' IROC
It sure sounds like an air flow problem to me. I don't think a new tstat or water pump is going to make any difference. What plastics are you missing underneath?
Old Sep 20, 2012 | 06:52 PM
watajob's Avatar
Car: 92 T/A 'vert
Wire your fans on constantly. If the problem mitigates, it's an airflow issue.
Old Sep 22, 2012 | 11:48 AM
Car: 1988 Iroc-Z
I have an air dam & nothing else as far as plastics go.
The fans are on a keyed switch already.
It has to be an air flow problem but I cant figure out what's causing the problem lol
Old Sep 22, 2012 | 11:54 AM
87350IROC's Avatar
Car: 87' IROC
Why don't you reinstall the plastics and see if that helps. They are there for a reason. I'm not saying the reason is airflow to the radiator, but I would be surprised looking at the shape of the lower nose underside piece.
Do you have anything blocking the radiator from getting air from the fog light holes?
Old Sep 22, 2012 | 12:47 PM
Car: 1988 Iroc-Z
The plastics weren't on the car when I bought it & I don't have any to put back on it. Nothing blocking the fog light holes either. I have a grill insert but that's it.
Old Sep 22, 2012 | 12:51 PM
Car: 1988 Iroc-Z
After looking at some pics of the plastics for the undercarriage, the only ones I am missing are the L&R pieces that extend from the air dam.
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
sreZ28
Aug 14, 2015 07:48 PM
