1992 z28 heating up in street
Old Sep 23, 2012 | 09:49 PM
Marcos123's Avatar
Car: 1992 camaro z28
Okay here what going on my car starts to heat up 10,15 min after driving it on the street and the oil pressure drop low according to the gauge but on the freeway it drive fine.And one more thing I want to add the other day I left the car parket with the motor running for about 25 min and everthing was fine it just when I get it on the street it give me problems maybe you guy can help me out with things I can check
Old Sep 23, 2012 | 11:12 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: 1992 z28
You need a better oil and check to see of your fans are working. The hotter a car gets the oil gets hot and cheap oil gets thinner the hotter it gets. Try mobil one 15w50 from autozone and check if your fans are coming on.
Old Sep 23, 2012 | 11:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1992 z28
" It gave me problems" No way to know what that means. You need to describe what happened and what specific problems developed for anybody to know what it might be
Old Sep 24, 2012 | 05:18 PM
Marcos123's Avatar
Re: 1992 z28
Ian going to change the oil and the the fans are working fine all I mean with it giving me problems is that it starts to heat up before this problem one or two fuel injector were bad so they were replace I don't know if that has anything to do with this heating problem but it didn't heat up before
Old Oct 10, 2012 | 10:53 PM
Marcos123's Avatar
Re: 1992 z28
Okay I got around to changing the oil it fix the oil dropping but it's still overheating on the street but not the highway. The fans are working right checked the radiator it find I was hoping someone can give me a list of things to check for I will really appreciated
Old Oct 15, 2012 | 10:19 PM
JOEM's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
Re: 1992 z28
I have the same heating problem and when it is moving it runs around 160 and standing it climbs to 240 then the one fan comes on to drop it to 200.
It should be the thermostat that is causing it. Run the car and feel the upper radiator hose. If the hose feels like it is under allot of pressure and very firm when the fan comes on the t-stat is not opening.
It should be the culprit. I used a thermal scanner to verify that my temp gage was correct and it is on the money.
https://www.thirdgen.org/forums/cool...-diagrams.html
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
diana227vegas
Jul 8, 2016 12:27 AM
zayne0
Aug 24, 2015 07:22 PM
Bryan F
Aug 18, 2015 02:28 PM
