3.1 TB Bypass Help and Ideas
Old Sep 27, 2012 | 04:44 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
On my 92 w/3.1, there is a metal fitting/elbow/piping is coming from the intake manifold, under the thermostat housing. It splits the water flow into 3 paths. 2 nipples to function as the TB warming loop, and a hard pipe running to the heater valve by the right fender. This is different than all of the other TB bypass threads I have seen, probably because a 3.1 was only a 2 or 3 year run in thirdgens.
If looking to delete it altogether to get rid of the TB coolant loop, and run a line from the intake manifold directly to the heater valve, here's your ticket. I've seen someone on here do it with Earl's fittings, but that will set you back at least $40 (cheapest I could find, on anplumbing.com for reference) for a couple little fittings. Also, anodized pieces feel out of place on the car to me.
For future search reference, a brass 1/2" npt male to 5/8" hose barb adapter is what is needed to bypass this with about a foot of 5/8" heater hose connecting a small section of the old metal line (which was cut behind the alternator) to the barb. I've also seen the adapter in stainless steel and chrome. I wouldn't hesitate to use stainless steel either.
Hope it helps someone in the future that is strapped for time, cash, or both!
Attached Thumbnails 3.1 TB Bypass Help and Ideas-img_20120927_141203.jpg   3.1 TB Bypass Help and Ideas-img_20120927_141209.jpg
Old Sep 28, 2012 | 12:14 PM
Car: 92 RS
Engine: a slow one
Re: 3.1 TB Bypass Help and Ideas
Nevermind, found what I needed by hacking it out of there anyway to get a look at the thread size.
See O.P. for solution
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
