Flex-a-lite 31149 Fan Controller
Old Dec 9, 2012 | 02:34 PM
jpearsall187's Avatar
Has anyone used this controller? I have an 88 camaro iroc 5.7 with the dual fan setup. Will this fan controller work with these fans?
Old Dec 9, 2012 | 05:35 PM
Re: Flex-a-lite 31149 Fan Controller
I guess what it boils down to is what amperage does the stock dual fan setup draw? What does each fan draw when it first starts up and when it is running? The flex a lite controller is rated for a combined 40 amps, so if both fans won't draw more than 40 amps combined at startup (they would be wired to come on together at the same time), then it should be good.
Old Dec 10, 2012 | 01:07 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
If this is the one that is a black box with the **** on front for dialing in when you want the fan to come then I have been using it with the Taurus fan. It works perfectly.
Old Dec 12, 2012 | 06:45 PM
one92rs's Avatar
Car: SOLD!!!!!
i am using this one and it is just slightly more. actually this is the fourth flexalite controller i have used. it comes on at 60% at first and speeds up to 100% only if needed.
http://www.summitracing.com/parts/flx-31165
Old Dec 14, 2012 | 11:06 AM
Anyone? Anyone know just the amp draw on the fans when they start up?
Old Dec 31, 2012 | 01:22 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Can't be more than the dual flex-a-lite fans it works with.
Old Jan 21, 2013 | 09:25 PM
one92rs's Avatar
Car: SOLD!!!!!
your factory dual fans wont draw more than my 4th gen fans or the big truck flex fans I have used. they are like 40 amps. it will work great.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
formula1LE
Sep 12, 2015 08:31 PM
scottmoyer
Sep 7, 2015 07:06 PM
85Special
Sep 3, 2015 04:21 PM
