Heater Core
Old Dec 23, 2012 | 04:36 PM
leezickmund's Avatar
Car: 92 Camaro RS
Engine: 305 Tbi
Heater Core
Ok, just a shot in the dark for a quick temporary fix. My heater core recently started to leak and push the nasty steam through my vents all at once. My fan switch on the HVAC control is already broken so I am already heat-less. Now im looking at the in and out tubes on the heater core that are poking through the firewall, and theoretically couldn't i disconnect the two hoses from the firewall and connect them together to simulate the coolant loop until I can get the time to replace the heater core? Need a quick reply if possible.
Car is a 92' RS w/ 305 tbi, all stock parts still other than exhaust, 5-spd, t-tops.
Thank you in advance for all of the upcoming, if any, advice. Ive tried searching but all I can find are threads that discuss removal and installation of the heatercore itself.
Old Dec 23, 2012 | 04:41 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Heater Core
YES you can do that, good luck.
Old Dec 23, 2012 | 06:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Heater Core
Works fine, but when you go to the store for fittings remember one hose is 3/4" and one is 5/8".
Old Dec 23, 2012 | 06:35 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: Heater Core
That's what I had to do to my girlfriends car. Works fine for me. You can find hose connections and clamps at any part store.
Old Jan 2, 2013 | 03:09 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Heater Core
Yeah it's called the heater core bypass. Many Fox body guys do this as replaceing the heater core on a fox body is worse than doing an engine swap LOL!
Old Jan 2, 2013 | 06:29 PM
fervernt's Avatar
Re: Heater Core
Or fords in general. Girlfriend has an 87 crown vic with th heater core bypassed cuz I wasn't gunna try and mess w that one LOL
Old Jan 2, 2013 | 11:03 PM
Car: 92 Camaro RS
Engine: 305 Tbi
Re: Heater Core
Hey, thank you everyone for the quick answers and humor! Sorry for my own slow response as well. Its completed and works fine!
Old Jan 4, 2013 | 03:46 PM
fervernt's Avatar
Re: Heater Core
any advice on getting that second hose off? the one closer to driver side? because my heater core just went out too lol. I want to bypass it, but I just can't seem to get that second one to budge.
Old Jan 4, 2013 | 06:34 PM
Guest
Guest
Posts: n/a
Re: Heater Core
Guys....bypass the heater --->at the water valve<---
Old Jan 4, 2013 | 07:45 PM
fervernt's Avatar
Re: Heater Core
Damn... that's actually a really good idea LOL. so what just connect the two connections together? Would that work?
Old Jan 6, 2013 | 10:02 PM
Car: 92 Camaro RS
Engine: 305 Tbi
Re: Heater Core
Now i feel dumb. Ha. I did struggle as well with that little hose where it runs down kind of down towards the wheel. I just twisted and pulled and cussed and pulled. What I ended up doing was running a new hose from where the smaller j looking hose goes into the lower engine bay (the hard one to get off) straight to the valve where the other heater core hose connects. Make sure that the fitment is good and tight. This is of course temporary but working with zero problems.
Old Jan 7, 2013 | 10:54 AM
fervernt's Avatar
Re: Heater Core
Well I got my heater core bypassed. would have done it at the valve, but I already managed to get both hoses off, so I figured I'd just finish it up that way. also, wanna thank GM for putting the WORST possible hose clamps on there, in the most inconvenient place possible lol
Old Jan 7, 2013 | 11:36 AM
Guest
Guest
Posts: n/a
Re: Heater Core
and dont you HATE of their clocked!!! I was like "and how in the fack am I gonna get this sh$t off..."
chalk another 1 up to the dumb 80s Gm engineers...
Old Jan 7, 2013 | 10:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Heater Core
You just have to have the right tool for the clamps and its a breeze.
Old Jan 7, 2013 | 10:57 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Heater Core
be advised that you do not want a aluminum heater core replacement when the time comes for you to repair it correctly.they lose too much heat and thusly dont provide very much heat .just have your OE core repaired at any radiator shop and you will be MUCH happier
Old Jan 17, 2013 | 10:58 PM
fervernt's Avatar
Re: Heater Core
Appreciate that advice, I never would have thought of that.
Old Jan 24, 2013 | 09:39 AM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
Re: Heater Core
Rusty vango thank you for that information. Currently doing a heater core in 16* weather =] thank you murphy for blowing my heater core the coldest week in a decade...
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
