Help with removing AC box
Old Dec 29, 2012 | 12:20 PM
xavier_pr84's Avatar
Im in the process of removing my AC I can say I'm about 85% done i removed just about everything . I just need help with the AC BOX . I'm stuck at this point so if anyone with the knowledge on this can input them i would appreciate it.
Old Dec 29, 2012 | 03:00 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Help with removing AC box
I think there are a couple bolts from the inside, IIRC.
Old Dec 29, 2012 | 03:57 PM
under the dash?
Old Dec 29, 2012 | 04:58 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Yup. Peel back the carpet and they're right there. 10MM, IIRC.
Old Dec 29, 2012 | 07:00 PM
great thanks ill do it tom then i can buy my ac eliminating box
Old Dec 29, 2012 | 07:04 PM
Twin_Turbo's Avatar
Yup 3 of them they go into the plastic plugs in the lower part of the box. Your non AC box will have only 2 of them so you will need to plug the remaining hole.
backtothe80s
Sep 5, 2015 12:39 AM
midias
Aug 15, 2015 05:07 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
