Please help with dual fan set up
Old Jan 11, 2013 | 03:08 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello,
This past summer I was having overheating problems with my 1984 (355)Camaro. The car has a single electric fan and is controlled by an aftermarket fan controller (derale fan controller) The car ran well with this single fan set up for a few years and then this summer the fan motor started making noises and the fuse would blow time after time. The last time it did this it blew the fuse and melted the fuse holder so badly that I had to replace it. Long story short, the fan motor was pooched so I went ahead and found a dual fan setup from a 89 Gta. I was able to control when my single fan came on but now that I have this dual set up I am not sure what I need to do to make this work. I was reading here at TGO and from what I gathered I want the drivers side fan to come on at 185-190 degrees and the passenger side to come on at a higher temperature. Wondering if I can run both fans off my derale fan controller? you have any advise or experience with this please share.
I found this dual fan controller, from derale...
Amazon Amazon
Old Jan 11, 2013 | 03:34 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Please help with dual fan set up
I have the exact same question . so maybe somebody can help both of us out.
Old Jan 11, 2013 | 09:07 PM
Engine: 355
Looks like we are in the same boat there Old blue.....lol
Old Jan 11, 2013 | 09:15 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
One of the fans were actually meant for using the AC. But they both can be used for cooling. I use mine that way on my drag car. I would assume you could wire them together somehow but possibly have to run heavier gauge wires to the control and a larger fuse. Or wire up a separate switch all together through a relay.
Old Jan 11, 2013 | 09:20 PM
Car: 1990 z28
Engine: 5.0
im sure we both thought of that already. but I want mine as factory set up was . but I appreciate any and all advice. so thanks for the input.
Old Jan 11, 2013 | 11:13 PM
Engine: 355
The thing for me is that my 1984 Berlinetta didn't have electric fan, so this is in no ways stock for me. I may end up using the relay idea as that is also what a mechanic friend had suggested to do. I do like the derale dual fan controller. I was looking around on google and seen this dual fan controller,http://www.frsport.com/DIF-10085-The...C_p_15992.html
Let me know what you guys think.
Old Jan 12, 2013 | 06:28 AM
Car: 1990 z28
Engine: 5.0
yea thats the ticket . i'm getting that . when i said I wanted stock ,I guess I meant I didn,t want to run some wires and a switch. this looks like a good mod.
Old Jan 12, 2013 | 10:01 AM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Try searching for a document written by moderator Willie. It's very complete, with part numbers and descriptions for various relays, thermostats and fans. Tons of suggestions.
Old Jan 12, 2013 | 12:45 PM
Engine: 355
I searched and found the thread you were referring to called, "Willie's updated Total Fan Control"
https://www.thirdgen.org/forums/cool...total-fan.html
Going to read it now. Thank you for the link two-if-by-sea.
Old Jan 12, 2013 | 01:06 PM
Engine: 355
Well the links for the single and dual fans are dead but further on in the thread a member reposted this one on the dual set ups. I think it may be the original article. Lots of interesting reading here. http://members.rennlist.com/3liter6/cool8dual.pdf
Old Jan 12, 2013 | 02:57 PM
Yes, that's the one. I knew it was out there somewhere. This post is what I was talking about. I have a copy of the PDF stored on my computer:
https://www.thirdgen.org/forums/post...05-post44.html
customblackbird
Aug 15, 2021 10:16 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
