heater blows only cold air
Old Jan 31, 2013 | 06:57 PM
biglano's Avatar
Car: 89 formula
Transmission: 5 speed
when temp is up, still blows cold air. air mostly comes out of the defroster no matter where the control is selected to. has plenty of coolant. heater core is not plugged, i flushed it out. when i slide the heater control from cool to hot, i can hear it opening the vent.
thanks for any help||||!
Old Jan 31, 2013 | 08:04 PM
sweetmelissa's Avatar
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
Re: heater blows only cold air
could be the thermostat
could be the water pump
take the cap of the radiator and see if its flowing also check radiator fluid level
Old Jan 31, 2013 | 08:58 PM
Chad85T/A's Avatar
Car: 85 T/A
If the heater hoses are good and hot when the engine is at operating temp its your selector or the blend door. Since your air all comes out your defrost I'd say you have a problem w the selector or in the heater box.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
