headers are getting red hot help!!
Old Feb 2, 2013 | 10:58 PM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Hey what up guys this is what's going on, a week ago I got my engine and transmission total rebuilt but its been heating up at idle when waiting for the light to turn green, it has a brand new radiator and thermostat. today I drove my wife to work which is 40 miles round trip I noticed it was getting hot so as soon as I exit the freeway and start driven on the street it gets even hotter and its running like crap I lose power and trany feels like its slipping. well I make it home open up the hood and my headers are glowing red hot. I'm thinking cats are plugged but not sure. what do you guys think it could be. I would appetite any help and thank you in advanced.
Old Feb 2, 2013 | 11:01 PM
saldav420's Avatar
Transmission: 700r
Re: headers are getting red hot help!!
Appreciate*
Old Feb 3, 2013 | 12:07 AM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
running lean will cause the headers to glow and the engine to run hot.
Old Feb 3, 2013 | 12:12 AM
saldav420's Avatar
Transmission: 700r
What makes it run lean?
Old Feb 3, 2013 | 12:50 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
"late"ignition timing can cause the glowing headers too.
Old Feb 3, 2013 | 01:03 AM
saldav420's Avatar
Transmission: 700r
You guys don't think it could be a clogged converter. I also noticed my exhaust sounds like ****. I guess I'll check it in the morning. timing, fuel, etc. and if that doesn't work I'm cutting the converter out. I would still like more suggestions so please reply. thanks
Old Feb 3, 2013 | 04:58 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
You likely have unburned fuel in the exhaust. Either too rich or retarded timing.
Old Feb 3, 2013 | 09:23 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
A clogged converter could cause it as well but check your timing and fuel first. Cheaper to fix than replacing a converter.
Old Feb 3, 2013 | 09:28 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Timing
Old Feb 3, 2013 | 09:31 PM
saldav420's Avatar
Transmission: 700r
Yup it was the converter, couldn't see daylight through that thing.
Thanks fellas for all the help
Old Feb 4, 2013 | 11:22 PM
89camaro355's Avatar
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Glad you starightened it out. I thought for sure it was too much timing
Cornholio7979
Sep 20, 2018 02:31 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Prodigious
Oct 4, 2015 11:20 PM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
