Overheat problem
Old Feb 6, 2013 | 11:23 AM
Retrostylz's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L 350
Transmission: Automatic 700R4
Overheat problem
I have a 5.7 L V8 Formula 350 firebird that will overheat when driven for long periods of time.
I've got coolant that will keep the temp down, but it literally begins to boil if I drive over 30 miles.
The gauges work fine. I'm just wondering if flushing the radiator will help keep it cool? I don't have much money since I am rebuilding the transmission, so anything that will work that is cheap is a great help.
Thanks.
Old Feb 6, 2013 | 11:36 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Overheat problem
Have you checked the obvious stuff? Do the fans work and do they come on at the right temp.? Check that the thermostat isn't corroded shut.
Old Feb 6, 2013 | 05:51 PM
Tried a new radiator cap?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
