simple ? about water pumps
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I have a 87 v belt/ ribbed belt set up on my car. I have a aftmrk alm water pump can I use that pump on a serp set up any why do eveyone wants the serp set up does it use less energy to move. I dont plan on putting a procharger on it. I was told that serp water pump is revers flow. I thought that was LT1
Re: simple ? about water pumps
No, your stock setup is normal rotation, full serpentine uses a reverse rotation pump. This because of the way the belt wraps the pulley
LT1 is reverse flow cooling
ok I will probably sale this they go for so much 300 + shipping I got it free why do ppl like them so much
Right: you don't have a "serpentine" belt. Just a wide flat ribbed one, of the same style as "serpentine" drive systems use.
"Serpentine" is derived from Latin; means "snake-like". Re. belts, it means ones that kind of wind their way in loops all around among the accessories.
If the belt drives the pump with its inner side (the ribbed side, in your case) it's forward rotation. Most serpentine systems drive the WP with the back (flat) side. That turns it the opposite direction. "Reverse rotation". A whole other thing, different from "reverse flow". The serpentine systems for typical small blocks still suck in at the lower hose, and blow out through the legs, then the cool water goes into the block, up through the heads, and out the top. The LT1, the cool water goes into the heads, down through the block after it gets heated up in the heads, then out the bottom.
People tend to prefer the serpentine drive systems because the belt stays put better, and generally causes less trouble. They may THINK it has to do with "energy", but they're deluding themselves if they do.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
