coolant fan problems
have 87 firebird with holly carb 305 5.0l
getting really frusterated everytime i crank the engine to my car over it blows my ch fan 20 amp fuse fan works direct fine just changed the relay over today what or where could the problem be
ps when i turn the ignition on not cranking it with ac on fan runs and doest blow fuse but when i crank it itdoes
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: coolant fan problems
Power = Current x Voltage.
When you crank it, what happens to the voltage and thus the amp draw for the fan motor?
Your stock fan should NOT have a 20 amp fuse in line with it. It should run through a fusible link from the starter terminal through the relay. Bottom line here is, maybe, a hack job?
is there any other way id hate to half to flip a switch everytime my cars hott
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you can install a derele fan controller or a cylinder head temp sensor and wire to the ground side of a relay like tbi cars use.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Side note = that controller is running my large 16" front pusher fan and only uses a 20 amp fuse.
http://www.autozone.com/autozone/par...artNumber=true
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Why is it when asking a question that, for the people trying to help, it doesn't require a cap'n crunch decoder ring to figure out what is being asked ?
If you can state your question in a clear and concise format with punctuation, it really helps everyone else to help you.
Engine: Lb9
Transmission: M20
If you can state your question in a clear an concise format with punctuation, it really helps everyone else to help you.
The stock fan will pull more than 20 amps on start up, maybe not every time, but eventually (when the voltage drops). I've done a few electric fan conversions using the stock setup and have found that a 25 A fuse is needed.
eightsixseven
Dec 16, 2024 01:50 PM
