Fan Help Needed
Old Mar 4, 2013 | 11:30 AM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Fan Help Needed
<<<<<------Car
I believe this (see photo) is the switch above starter that activates the fan relay. Please correct me if I am wrong. I am guessing that if you ground the wire that goes to this switch the fans will run all the time....? If this is true, what color is the wire that goes there and where does it enter into the loom on the harness; Is it the loom that carries the starter wires or the loom that runs along passenger side valve cover? Thanks for any help.
Old Mar 4, 2013 | 11:46 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Fan Help Needed
Originally Posted by MrPackstin
<<<<<------Car
Can't recall the wire color or which way it ran originally (I think in the starter harness)....but yes, if you ground the switch connector, the fan should turn on.
If it doesn't turn on when you ground the connector, you either have relay or wiring issues - not switch issues.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
