AC cycling problem
Old Apr 3, 2013 | 07:35 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
AC cycling problem
1991 Vert 5.0 a/c retrofitted and developed a strange problem.. Ac blows cold, pressures are in the normal range. AC clutch kicks off and then wont engage for a while. If I rev the motor in gear while driving (like kick it into passing gear) it will engage. It then eventually will disengage. I tried jumping the low pressure switch, but still wont engage. But here is the kicker.. If I tap the front plate of the clutch, it engages. Almost seems like the magnet that pulls that plate to lock the clutch is weak.. Any ideas what to check or what the issue may be?
Any help is appreciated
Old Apr 4, 2013 | 03:03 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: AC cycling problem
Make sure you are getting a strong 13V at the clutch coil. Clean the connector and the pins, a little corrosion will reduce the voltage.
Old Apr 26, 2013 | 12:26 PM
joecool108's Avatar
Engine: V8, V8, V6
yes 13 volts at the coil, what should I check next?
Old Apr 27, 2013 | 08:11 PM
knightrider5000's Avatar
Car: 1989 Formula 350
Axle/Gears: 3.27 Posi
At least its blowing cold,I too have a 91 vert and it will not blow any cold air, I tried adding AC refridgerent. Now I see my compressor is not cycling at all with the ac on. Do you know where the power to the ac compressor clutch is at? So I can bypass it to see if it works? I have looked online but no luck. And all my relays seem to work.
Old May 3, 2013 | 12:19 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Your clutch coil gap could be too big. Use a feeler gauge and see. If not the coil internal to the compressor might be failing
Posted from Thirdgen.org App for Android
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
