Question about hawks A/C delete box
Old Apr 11, 2013 | 10:15 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Hey guys i had a question about hawks delete box that i just purchased. I noticed it doesnt have that hole to put in the resistor. What do you guys recommend me doing or do i just remove it? Would i have to make a hole on the box for it? Thanks in advance!
Old Apr 12, 2013 | 07:02 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Question about hawks A/C delete box
I would like to know too!
Old Apr 14, 2013 | 11:01 AM
robg91z's Avatar
Engine: 350ci TPI
bump!
Old Apr 14, 2013 | 03:57 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I would say you need to make the hole. The resistor needs to be in the airflow to keep it cool. If you bypass it you will only have one fan speed, high.
Old Apr 14, 2013 | 05:20 PM
robg91z's Avatar
Engine: 350ci TPI
so if i disconnect the resistor, the blower will still turn on but only in the high speed position? i mean i dont really mind of the speed of the blower in which i probably wont be using that much until the winter time so i guess i just leave it disconnected? i dont feel like messing up the new box and drilling thew it yet lol
Old Apr 14, 2013 | 06:39 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
I'd say just take a dremel to it
Old Jul 24, 2013 | 11:02 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
The hell with buying a ac delete, I made my one from the factory ac box, still has resistor hole and looks clean, fiberglass and dremel tool are your best friend!
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
