Lost temperature sending wire
Old Feb 27, 2013 | 03:51 PM
ironfistofgumby's Avatar
Car: 1991 Z-28
Engine: Supercharged 354 c.i. sbc
Transmission: Stage 2 700R4 from Jasper Engines
Axle/Gears: Custom Ford 9", Detroit Locker:3.55
Hey fellow enthusiasts! I hope this is the correct board to be posting in, I'm fairly new to this site. Joined a year ago but haven't been around to participate like I want.
Anyways, I just rebuilt my engine and in the process of putting it back together, I accidentally pulled on the temperature sending wire that goes to the firewall out. I have been unsuccessful in relocating the pin in the firewall for this and am considering running a whole new gauge in place of it, even though I really want to be able to use my stock gauges. I assume it may be located behind the master cylinder, but I am hesitant on removing it for just one wire.
It is on my 1991 Z-28.
Any suggestions? Pictures?
Old Feb 27, 2013 | 03:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lost temperature sending wire
https://www.thirdgen.org/forums/ltx-...formation.html
Old Feb 27, 2013 | 06:46 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Welcome to TGO! Glad you finally made your way to posting and joining the forum proper!
Old Feb 27, 2013 | 08:55 PM
Car: 1991 Z-28
Thanks for the welcome! Really enjoy this site and its full of great ideas.
And thanks Tunedperformanc for the help. Will look the thread over, hoping to see something helpful.
Old Feb 27, 2013 | 09:20 PM
Engine: Lb9
Transmission: M20
The thread has a picture of c100 the bulkhead connector bye you master cylinder.
Old Feb 27, 2013 | 10:45 PM
Car: 1991 Z-28
Thank you
Old Jul 24, 2013 | 11:26 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
I'm so glad I just found this thread, I've been searching for that wire for awhile, the previous owner gutted the tpi harness and just dropped a junk motor in and left all the wiring jacked. I've had to rewire the whole car almost, the guy actually cut the trans lock-up and cost me $2400. (I went all out, Kevlar bands and clutches)
BlueIroc-Z
Jun 9, 2019 03:22 AM
Infested
May 22, 2018 11:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
djmarch
Aug 19, 2015 12:07 PM
