N00b air dam/fan questions.
Old Apr 13, 2013 | 04:01 PM
Flightoficarus's Avatar
Hey all, so although not far into it, I've finally resumed work on my bird. All I've really done so far is removed a few things like the air cleaner and fan assemblies, as I'm getting ready to remove my A/C stuff, do a full compression test on the 305 (to find out if it's truly on it's way out or not, though I suspect it is), and also, to install an air-dam, as it appears my car doesn't even have one on it, shown in the pic below.
Obviously, I should install an air dam ASAP, and am probably just gonna snag a new one online, since they're cheap, and often times, I find them to be missing on many scrapyard cars too. My only question is, since I wouldn't know due to not having one, it it supposed to mount in the location shown in the pic? Right below the front of the core support?
I also have fan/airflow questions in regards to cooling as well. Since I'm removing the A/C system, and thus, the condenser in front of the radiator, will this significantly improve airflow going to the front of the radiator to help keep it cool? Also, how effective is the stock single fan used with the 305 TBI? Is it powerful enough to keep a 300 HP-ish SBC cool? (Planning to do a swap/mods)
Old Apr 13, 2013 | 04:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: N00b air dam/fan questions.
Yes.. there was certainly one there at one point in time...
Attached Thumbnails N00b air dam/fan questions.-8andjtvt.jpg
Old Apr 13, 2013 | 04:55 PM
Thank you much for that visual pointer there!
Hopefully someone can chime in on my cooling questions relative to the condenser removal/TBI fan power as well.
Old Apr 13, 2013 | 05:36 PM
deadbird's Avatar
Engine: TPI 305/ v6
Yes, it will improve airflow, I'm not sure about greatly, unless your condenser is a total mess. you'll want something to seal the side gaps between the radiator and support (sheet metal)to from taking out the condenser, to help assure air is going through the radiator and not around it.
And the stock cooling system should easily be up to the task of a 300hp motor, the stock 350 was 245. +55hp isn't to extreme.
Old Apr 14, 2013 | 10:44 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
https://www.thirdgen.org/forums/body...r-air-dam.html
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
IROCZ1989
Sep 4, 2015 11:54 AM
tonys91rs
Sep 2, 2015 07:07 PM
