Need help & info. about a Water pump.
Old May 9, 2013 | 03:50 PM
Hollow_kmh's Avatar
Car: 1989 Camaro RS
Engine: V-8
Transmission: 5 speed
I'm sorry I'm new to this. I have a couple of questions about my water pump for my 89 Camaro RS. (5.0 Liters)
1) What happens if you spot a leak on your water pump coming from a weep hole?
2) Can you fix a leak weep hole on a water pump?
3) What does a weep hole on a water pump do?
Thanks.
Old May 9, 2013 | 06:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Need help & info. about a Water pump.
1-means the shaft seal is leaking
2-shaft seal will need replaced-usually the water pump is replaced as a press and other special tools are needed to replace the seal
3-weep hole is a path for coolant seeped/leaked from the seal to escape instead of going through the bearing and ruining it.
Old May 12, 2013 | 10:51 AM
Hollow_kmh's Avatar
Car: 1989 Camaro RS
Engine: V-8
Thank you very much.
Old May 12, 2013 | 11:15 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Time for a new water pump. They're stupid cheap and easy to install. Replace your hoses while you're there.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
